Select and delete point at specific elevation
lollazzo
Post by lollazzo »
I want to delete points which are at a specific elevation or in a specific range. What I have to do?
Thank you for the help
Re: Select and delete point at specific elevation
Just convert the (Z) coordinates to a scalar field with 'Edit > Scalar fields > Export coordinate(s) to SF'.
Then use the 'Edit > Scalar fields > Filter by value' to filter the points with specific scalar values (the Z coordinate here) falling in a specific range.
