Saving picked points
kalliopikout
Post by kalliopikout »
I have made an intersection on a point cloud, then a picked a point and saved its label by pressing ''save current label-added to cloud children).
The point appears on the panel below the intersection, but when I am trying to save/export the point I get an error '' Dependency broken: entity 'merged_all - Cloud.section' must also be in selection in order to save 'Point #1'''.
The problem is that I cannot select both at the same time...
Thanks in advance for your help!
Kalliopi
Re: Saving picked points
Actually you just need to select the cloud (labels are children of this cloud, and will be automatically saved when exporting the cloud to a BIN file).
The issue is that you will export a 'label' and not a point. And no other format than BIN support 'labels' anyway.
You should actually use the 'Point list picking' tool (https://www.cloudcompare.org/doc/wiki/i ... st_picking). This one lets you pick one or several point, and actually export them as a new cloud or as a file.
kalliopikout
Thanks a lot! Both options are very useful to me in any case!
Have a nice day,
Kalliopi
