Compute Normals on PTX
PMDevine
Post by PMDevine »
I am calculating normals on a structured PTX cloud using the COMPUTE_NORMALS command. It seems like it does a really good job, but the normals are inverted. I always need to go into the GUI and "invert normals" for them to visually seem correct (based off the white/black color). It seems that the normals are outward facing instead of inward facing like I would expect them to be. Is there any way to specify that the normals point inward using the COMPUTE_NORMALS command? Or is there any way to invert the normals in command line?
Thanks,
Phil
Re: Compute Normals on PTX
Normally, we prefer normals to point outwards by default (for most objects). But of course it doesn't work for indoor scans for instance.
And that's silly, but currently there's no way to invert normals. I've added an option '-INVERT_NORMALS' to the command line of the latest 2.12.alpha version.
PMDevine
Post by PMDevine »
Awesome, thanks so much, Daniel!
The latest 2.12.alpha version is now online (previously, this new INVERT_NORMALS option was not active!)
