obj texture file
Emsali
obj texture file
Post by Emsali »
Hi!
I´ve tried to load an OBJ with jpeg texture file. Unfortunately, cloudcompare isn´t able to load the jpeg ["Failed to load image"]. I´ve read that a possible failure is the image size (180 mb). Is there a possibility to split or resize the image without losing the metainformations of the image??
Cheers
Re: obj texture file
You can definitely resize the image with an external tool (just keep the same name, or update the image name in the .mtl file). And keep the aspect ratio as well.
