RGB to IHS
Re: RGB to IHS
Eventually I took some time to implement this method.
You'll find it under 'Edit > Colors > Enhance with intensities' in the latest 2.8 beta version.
I couldn't find clouds with clean intensities and bad RGB colors. Therefore I couldn't test it properly. Can you try it on your side? And see if you get the same results?
Haowyr
Re: RGB to IHS
Post by Haowyr »
Seems good to me, and wayyyyyyyyyyyyyyyyyyyyyyyyyyy faster, thanks :) No need to code the command line to make it automatically ;)
jochemla
Re: RGB to IHS
Post by jochemla »
Hi daniel,
Not sure I should post in this thread because of the posts following the original answer.
1- Are you planning on integrating the feature of RGB to HSV (in scalar fields), or can you point me toward the steps to code it and do a PR ?
This can be a useful addition for segmenting points with the same hue for example.
2- Another nice addition when filtering from scalar fields can be to have more complex filters for example SF1 in range (min1-max1) and SF2 in range (m2,M2) or SF3 in range (m3,M3).
Should I add them in the CloudCompare git repo ?
Re: RGB to IHS
1) The easiest way to do this would be to mimic the way 'MainWindow::doActionScalarFieldFromColor' works (it actually calls ccEntityAction::sfFromColor).
In 'ccEntityAction::sfFromColor' we display a dialog to let the user choose the exported fields, but you don't even need to do this (you can create 3 scalar fields, 'Hue', 'Saturation' and 'Value'). This will simplify the code a lot.
If you make a PR with such a 'ccEntityAction::hsvSFFromColor' method, I can connect it to the application menu if you feel a bit lost.
2) If you have such a tool (with dialog?) then don't hesitate to add them indeed (any contribution is gladly welcome ;)
ingoplem
Pipe and structure analysis
Post by ingoplem »
please i would like to know how to perform 3D modeling in CC?
Elbruno
Re: RGB to IHS
Post by Elbruno »
Hey Daniel, thx for implement the method!
I will test it, and will post the results ASAP.
Glad to see it in CC.
TYVM!
