get the point cloud in the window
All about Windows versions
zzwbeyond
Post by zzwbeyond »
Hello everyone,
I create my plugin in CC, and I want to get the point cloud in the window with my plugin. But I can't get using follow code:
	m_activeWindow = m_app->getActiveGLWindow();
	winDBRoot = m_activeWindow->getOwnDB();
	globalDBRoot = m_activeWindow->getSceneDB();
	ccHObject::Container toProcess;
	if (winDBRoot) {
		toProcess.push_back(winDBRoot);
	if (globalDBRoot) {
		toProcess.push_back(globalDBRoot);
	while (!toProcess.empty()) {
		ccHObject* ent = toProcess.back();
		toProcess.pop_back();
		if (!ent->isEnabled())
			continue;
		if (ent->isVisible()) {
			if (ent->isA(CC_TYPES::POINT_CLOUD)) {
				ccLog::Warning("point cloud is found!");
Is there something wrong with my code? And how can I do to get the point cloud in the cloudcompare window?
Re: get the point cloud in the window
You should look at how the other plugins work. For instance qHPR or qRANSAC_SD:
https://github.com/cloudcompare/trunk/b ... D.cpp#L111
	const ccHObject::Container& selectedEntities = m_app->getSelectedEntities();
	size_t selNum = selectedEntities.size();
	if (selNum!=1)
		m_app->dispToConsole("Select only one cloud!",ccMainAppInterface::ERR_CONSOLE_MESSAGE);
		return;
	ccHObject* ent = selectedEntities[0];
	assert(ent);
	if (!ent || !ent->isA(CC_TYPES::POINT_CLOUD))
		m_app->dispToConsole("Select a real point cloud!",ccMainAppInterface::ERR_CONSOLE_MESSAGE);
		return;
	ccPointCloud* pc = static_cast<ccPointCloud*>(ent);
zzwbeyond
Post by zzwbeyond »
Thanks, daniel.
I know this method, but I do not want to select the point cloud in my plugin. Is there some way to acquire the point cloud in the window without selecting the point cloud?
You mean that you want to get any cloud loaded in the DB tree?
In this case you can ask to the 'm_app' instance (ccMainAppInterface) the 'root' object of the DB tree with the 'dbRootObject' method.
You can then recursively search for all point clouds children (see the 'ccHObject::filterChildren' method).
