Delete scan grid command line
skarab
Post by skarab »
Hello every one,
Everything is in the title. Is there a command to do delete scan grid in batch ?
Tks for all
Re: Delete scan grid command line
It's possible now with the latest online 2.10.beta version: see option '-REMOVE_SCAN_GRIDS'
skarab
Post by skarab »
Sorry for the tardive reply and thanks for all.
Is there a way to install multiple version of CC? I already try once, but I have every time problems with the fls sdk. I'm always affraid of upgrading my versions and see this problem came back.
Well, I guess you could simply duplicate the default CloudCompare folder to another one with a different name.
Then you can install another version WITHOUT the FRO LS SDK. In this case the previously installed one should remain unchanged if I'm not mistaken.
