Surface of Revolution Analysis NEW bug
Getarq
Post by Getarq »
Thanks a lot for your last answer.
Now I Found a new Bug.
I'm doing the same work with storage tank, but now when i generated the 2d distance map, I¡m having problem with the DXF export! Problem that I didn't have in older version, and in 2.91 version is supposed to correct it =(
I also try the 2.10 alpha, but the problem persist.
PLeaseeee, what can i do?
Y try to open the file in different programs, the only one that open it was a global mapper, but i lost all the layers.
Greetings!
Hope you can help me.
Diego.
03 Verticalidad.rar
(368.87 KiB) Downloaded 1240 times
Diego Ramirez
Architect
www.getarq.com
Re: Surface of Revolution Analysis NEW bug
You were right! The bug was fixed in the DXF I/O filter (to save DXF files in CC). But not in the SRA plugin :(
It should be fixed now. Can you try with the latest online version?
Getarq
Post by Getarq »
NOUP =(
I downloaded the last 2.9.1 version! and still not working!
Or do you mean the 2.10 alpha?
I had to downgrade to 2.8.1 for continue working! luckily I still had it saved
Regards!
prueba.rar
(56.8 KiB) Downloaded 1431 times
Diego Ramirez
Architect
www.getarq.com
Yes, try the alpha (it's the only one that is not fixed and evolves constantly).
Getarq
Post by Getarq »
Daniel,
Thanks a lot for your help, time and of course for the quality of this amazing software!! and obviously for your amazing response speed :D
Now works fine :D
regards Daniel!!
Diego Ramirez
Architect
www.getarq.com
