Extract Z position value
mga302
Post by mga302 »
I have a lot of point clouds and for each of them X and Y position is 0 but not Z. I need to check the Position/Orientation properties and to apply the transformation extracting the Z position value to all points. Since I have to do the same for all of them and the value is not the same, some idea of how I could do it from command line?
Thank you!
Re: Extract Z position value
Sorry I didn't fully understand what you were trying to do. Can you explain a little bit more?
