"Windows fatal exception: code 0xc000001d" when trying to install PCL plugin
andrii302
Post by andrii302 »
Good day,
I have installed and used CloudComPy without any issues, but when it came to cloud registration I encountered a problem when trying to run following code:
import cloudComPy as cc
if cc.isPluginPCL():
    import cloudComPy.PCL
I get the following message in Spyder's console:
QFileSystemWatcher: Removable drive notification will not work if there is no QCoreApplication instance.
JsonRPCPlugin::JsonRPCPlugin
Main thread:
Current thread 0x000032f4 (most recent call first):
  File "<frozen importlib._bootstrap>", line 241 in _call_with_frames_removed
  File "<frozen importlib._bootstrap_external>", line 1176 in create_module
  File "<frozen importlib._bootstrap>", line 571 in module_from_spec
  File "<frozen importlib._bootstrap>", line 674 in _load_unlocked
  File "<frozen importlib._bootstrap>", line 1006 in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 1027 in _find_and_load
  File "C:\Users\yanovetsa\CloudComPy310_20240420\CloudComPy310\CloudCompare\cloudComPy\PCL\__init__.py", line 44 in <module>
  File "<frozen importlib._bootstrap_external>", line 883 in exec_module
  File "<frozen importlib._bootstrap>", line 688 in _load_unlocked
  File "c:\users\yanovetsa\ccpy\find_ridges.py", line 54 in <module>
  File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\py3compat.py", line 356 in compat_exec
  File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 473 in exec_code
  File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 740 in _exec_cell
  File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 689 in runcell
  File "C:\Users\yanovetsa\AppData\Local\Temp\ipykernel_10968\1630711856.py", line 1 in <module>
Main thread:
Kernel wird neu gestartet...
("Kernel wird neu gestartet" means "restarting the kernel")
I am using Python3.10, and the CloudComPy310_20240420 version, with miniconda3 on Windows 10 Enterprise LTSC operating system.
When trying to import other plugins the same way, like PCV plugin, I didn't get any error and it runs just fine.
Thanks in advance!
Re: "Windows fatal exception: code 0xc000001d" when trying to install PCL plugin
Maybe it would be better to ask this question on the project's github page (as an issue). I'm not sure Paul (the maintainer of the CloudCompy project)ever comes on this forum.
Unless you also get this error when running the standard version of CloudCompare of course ;)
