Display problem with rounded points
Posted: Sun Oct 25, 2026 6:37 am
by AndrewB
Currently using CloudCompare version 2.14, displaying a point cloud generated from a DIY LiDAR scanner. I'm trying to render these point clouds in an aesthetic way and I much prefer the "draw rounded points" option, as opposed to the square 'pixel' type points that are the default.
The issue I have is that when rounded points are enabled, they display differently depending on the location/orientation of the camera. Sometimes they appear correct (solid grey points) however other times they appear to have some kind of black ring around every point, leading to a very abrupt visual transition between the two types.
Here's a scene with rounded points turned on, you can see on the left half of the image the points look correct, on the right half however they have black rings around them.
Here's the same scene with rounded points turned off, all of the points look correct.
The rounded points almost behave like they have normals which are pointing tangentially to the origin of the scan. Whenever I point the camera at the scan origin the rounded points to the right of the origin have the dark ring and those to the left don't. This behaviour is persistent as I rotate the camera around the origin.
Does anybody know how to make the rounded points behave the same way as the square points? That is, make them all appear as solid colour to the camera, rather than having them behave as if they have a normal orientation with the 'back' side of the point appearing different to the 'front'?
Re: Display problem with rounded points
Posted: Sat Oct 31, 2026 12:40 pm
Hum interesting. The 'rounded' point option is managed by the driver itself. Maybe it has different implementations depending on the driver.
But I've just spotted an issue: if you highlight a cloud and press 'N', even if the cloud doesn't have normals it will slightly change the display! Can you test this on your side?
Posted: Sat Oct 31, 2026 2:09 pm
Ah, nevermind, the issue with the normals is actually linked to the same effect, but since it's random, whenever you type on a shortcut that forces the display to refresh, you see something change on the screen.
Posted: Sat Oct 31, 2026 10:10 pm
And this should now be fixed in the latest 2.14.beta version (the Windows version is now online).
Posted: Fri Nov 27, 2026 1:31 pm
by daria22
daniel wrote: Sat Oct 31, 2026 10:10 pm And this should now be fixed in the latest 2.14.beta version (the Windows version is now online).
Thanks for the quick fix. Is the Linux build of 2.14.beta getting the same fix, or only the Windows version for now?
Posted: Sun Nov 29, 2026 1:12 pm
I guess the beta should have it now? (as there has been a new pre-release recently)
