intersect point cloud with a mesh
nikoue
Post by nikoue »
Hello. I have a point cloud of an airport.
I also have made some theoretical obstacle limitation surfaces.
Is there a way to classify the points which are above these surfaces?
the surfaces are NURBS from rhino but i can convert them to a mesh file like obj.
Thank you.
Re: intersect point cloud with a mesh
Would computing distances between the cloud (points) and these nurbs surfaces be sufficient? (i.e. use the resulting distance to classify the points?)
nikoue
Post by nikoue »
thanks a lot i will try
Happy new year
