Fine adjustments on translate/rotate tool
Guitar Quackery
Post by Guitar Quackery »
Greeting,
In some cases I need to use the Translate/Rotate tool to make fine adjustments in the rotation of the cloud. At times I am unable to rotate precisely, because the cloud snaps into the nearest increment.
Is there a way to disable this snapping? Or perhaps to increase the resolution of the snapping?
Thank you very much.
Re: Fine adjustments on translate/rotate tool
Hum, not sure where the 'snap' would come from. Maybe it comes from the mouse?
c3kkos
Post by c3kkos »
I found that the rotation/translation increment method is WAY more flexible and precise compared to the mouse.
Coarse transformations with mouse, fine with steps
Guitar Quackery
c3kkos wrote: Fri Dec 05, 2025 10:54 am I found that the rotation/translation increment method is WAY more flexible and precise compared to the mouse.
Thank you for this tip.
Although, I am struggling to find the increment method with steps. Where is that adjustment please?
c3kkos
Post by c3kkos »
There is nothing special to do, mouse control is the default behaviour.
To use it, permit or restrict axes from rotating and/or translating using the tool window, it is all self-explanatory.
THEN use the mouse onto the 3d view to do what you need... it is basic usage and requires little effort to master it.
